For sale is a 1994 Defender 90. The truck has 115,000 miles. I have had it about 2 years, and am moving on to something bigger (110). I have done lots of upgrades and maintenance. The truck is set up for overland travel, being that it is very off road capable, but you can also drive it 75 mph down the highway. It has a 3.9 V8 motor and the LT77 transmission (shifts perfect in all gears). Also has CDL.
Upgrades:
-RTE +2' springs
-RTE rear links
-Rancho 9000 adjustable shocks (12' travel)
-EE spring retainers
-Spring isolaters
-GBR 4.14 gears front and rear thrust bolted
-ARB air lockers front and rear
-ARB air compressor
-Rovertracks rear HD axle shafts
-HD drive flanges in rear
-Rockware front buper
-Rockware diff guards front and rear
-Rockware rear shock mounts
-Custom built rear bumper with swing out tire carrier, 2 gerry cans, and hi-lift jack
-Custom build rock sliders (attach in 3 locations = no give at all)
-Warn M8000 winch
-Badger Coachworks badger II top
-5 BFG KM2 255/85/16
-5 Gulf Coast Rovers steel wheels
-HD sleeved panhard rod and track rod
-Tuffy center console with CD/mp3/ipod
-JL audio speakers
Maintenance done recently:
-new slave cylinder on clutch
-replaced, packed, and sealed all wheel bearings
-installed 100amp alternator
-installed new steering gearbox to eliminate a leak
-moved rear seat forward to allow for more storage room in the rear
-transmission flushed
Upgrades:
-RTE +2' springs
-RTE rear links
-Spring isolaters
-ARB air compressor
-Warn M8000 winch
-JL audio speakers
