'95 SR Starter Stuck on :(
Hey guys, pulled into my driveway, turned ignition off, and took key out, instantly starter was cranking. I popped hood and ripped (-) terminal off battery to stop. Anyway, pulled starter and it tested fine. Any ideas or input is appreciated!
IncorpoRatedX
put the key back in and move it around, see if it stops. If that works, start with the ignition switch. But either way it sounds like you've got some wire chasing to do.
TurboStagecoach
