96 Montero LS 3.0 VSS help
meclipsegt
The VSS itself works. Speedo works, but ECU doesnt show anything. so, Im looking at the FSM (13A-1076-1) and the VSS plug they show is a 2 wire, but the truck is a 3 wire. So, how do I test the wire for a ground to ECU then? Which wire goes to ECU pin #86 (thats what the FSM says, I hope its correct)? Thanks in advance.
TNielson-18
