97 MOntero LS
Jarhead74
Due to work requirements of more travel I have decided to part with my Montero and get back into a car. This sucks as I have put a lot of work into the Monty and have enjoyed it. I purchased the Montero almost a year ago in Atlanta. It had lots of work done to it due to timing belt failure. I will list everything done by the PO along all the things I have done. In fact yesterday I finished the last thing on my to do list and that was to replace the Valve Cover gaskets with Mitsu parts. The PO did replace these but with aftermarket brand and told me they still leaked some. As of today the Montero has 172k miles. last oil change was @ 170k. Its been on a 5k oil change cycle with mobil 1. Besides the few drips from the passenger valve cover there has been 0 oil usage at 172k!
As mentioned, I purchased this with 152k miles. The timing belt failed (was overdue) and caused damage to the valves resulting in a top end Rebuild. If you look at my main thread http://forum.expeditionportal.com/th...Gen-2-Feedback you can see the pics of the heads and engine during the rebuild. I have the folder with all the receipts for the work done from the PO.
Full Pics: https://augusta.craigslist.org/cto/6145148823.html
Top End Rebuild/Other Items:
Heads Rebuilt with new Valves/seals
Full Gasket set
Timing Belt/Water Pump/Tensioners/Crank Bolt
Radiator-Metal One/Hoses
Piston Rings
New Brake Pads on all sides
Since I purchased it, I have done several things to further improve/add some things.
Toyo AT Open Country 265/75-15 95% tread still left
New Bilstein Shocks 4/1/17
Manual Hubs
Front Bumper ends from Gen 2.5 with Fog lights. Has working factory fog light switch on the dash
Pioneer CD Player
New Heater Core 5/1/17 This was not a fun job
Valve Cover Gaskets (Mitsu Brand) 5/20/17
Rear Cam Seals Both Sides
Gen 2.5 Headlights (New) New Harness for the newer style Bulbs
Rear Swaybar links
4WD actuator
Transmission fluid completely exchanged/all diffs/transfer case fluids with synthetic
Brake fluid flushed
Fuel Filter repalced
Recovered the steering wheel with leather
The interior is in awesome shape with no rips or stains. Has the original Mitsubish floor mats that are clean. I have the 3rd row seat, but they are out in the garage. Will post pics shortly of interior. The sunroof opens and does NOT leak. Ac is nice and cold and now the heater blows hot air and does not leak-Bonus. The CV joints are in good shape and not torn.
Really the only thing is clear coat fade on the roof in front of the sunroof. The overall paint is in good shape with few minor scratches. Comes with 2 keys, owners manual and 1 key-less remote
Asking $3700 OBO for the Monty. Think this is a fair price for the shape/work put into it. Clean Title.
Attached Thumbnails Attached Thumbnails
