BaseCamp
So I did an advanced search and was unable to find my answer. So here is my question:
I have a 96 E350 7.3 with front ABS, the axles that I am swapping in are 06 f250's with ABS. I would like to make a pig tail connector between the old sensor connectors and the new sensors connectors. I had read on another thread that I would need to replace the 06 sensors with an 99-04 sensors, is this accurate or can I just plug and play with a homemade pigtail/splice job? My new bearings came with new sensors. I have pretty much everything else figured out and the axles rebuilt completely otherwise, with all the parts needed for the conversion in my garage, gonna get this finished up right after my elk season ends. Had to take a recharge day today to catch up on work, maybe I should have harvested one of those cows or the 5x5 that I called in this past weekend. Thanks!
