ReluctantTraveler
I have what I suspect is an extremely dumb question for people who understand electrical systems better than I do, so sorry in advance!
12v AC units (like the Dometic RTX 2000 or Mabru RVSC) seem to use a minimum of 19 amps while running (at their lowest setting), probably around 30-40 when doing more heavy-duty cooling. Both recommend at least 500 amps of battery for use, with cooling capacity of 12,000 BTUs.
The Coleman Mach 3 has a 13,500 BTU capacity, and their own website claims 18 amps of draw while running in desert conditions. They also now offer a soft-start adapter to lesson startup load.
Given that, is there any compelling reason to choose a 12v AC over the Coleman Mach 3, particularly if you're planning to have an inverter in your electrical system already? And how would you calculate the minimum amps required for that kind of setup? Is it the same as with a 12v system, or is there some "formula" to deal with the energy loss from using an inverter?
I'm also considering retrofitting our cheap travel trailer with some LioN batteries and inverter to have short-term off-grid AC until I can build our dream rig.
