Ac in a tear drop
Bobby6319
I am going to build a moby 1 style trailer with ac in the galley wall but I don't know how the do the drain,has anyone else done this how do you do the drain ?
Sb_Moto
well you just need to build a pan below the ac unit. I would use some angle aluminum, and a thin sheet of aluminum to build a tray. Most window units require some water in them to help cool the coils.
The bigger issue IMHO is airflow to keep the coils from icing up.
Given both of these problems and the amount of space a window unit takes up I am either going to use a climaright or take a standad window unit and convert it to a climateright (basically what a a climateright is anyways)
Bobby6319
Yeah I saw one where the guy converted one . Doing the climatright or converting one whould probably be the best thing and the you whouldn't have to carry it around in the cooler months.
Linesman1776
