what bracket it that for the table?
VERY NICE! where did you get that table top? anything underneath to support the load?I used the same bracket to make a removable table for the side of my trailer.
looks great! not sure i follow on the runner? are you using some UMHW for the drawers to slide on then sandwiching the table?good idea. I'd lose the sharp corners.
Too, our sort of drawer box / drawer front design would readily lend itself to a hinged front panel that folds down to be a table surface. Especially if the drawer box is tall enough. Mine are only 9" T so I left that idea behind and went with a pull out instead.
I chose to do a pull out shelf / table, built in under the drawer on one side. The drawers slides on runners in each bottom corner of the drawer box, with the pull out shelf nexted between the runners. The runners are ~1/16"+ taller than the shelf.
eta
i used the one from Patrick Metals, cheaper and faster delivery https://www.amazon.com/dp/B004OHTRE0/ref=dp_cerb_1Amazon.com: AP Products (013-164922 30.25" Table Support: Automotive
Buy AP Products (013-164922 30.25" Table Support: Furniture Parts & Hardware - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.comAmazon.com: GRIDMANN NSF Stainless Steel 12" x 36" Kitchen Wall Mount Shelf Commercial Restaurant Bar w/ Backsplash : Industrial & Scientific
Buy GRIDMANN NSF Stainless Steel 12" x 36" Kitchen Wall Mount Shelf Commercial Restaurant Bar w/ Backsplash: Rack Shelves - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
it was so shiny i missed the angled supportI ordered the bracket and the "table" from Amazon. It is a stainless steel restaurant shelf. If you look carefully at the end you can see the support against the wall of the trailer. It is SOLID!
