addind aux fuel
QCAuto
I just got an 01 PSD van, I am thinking for biodiesel I would run in a second tank, I was thinking also(sorry) of running a rear tank from a 97 f250 PSD with a fuel switch valve and lines from same truck, or the larger plastic tank from an fsuperduty. Anything special I need to know? Like in tank pump or anything? Thanks, scored this EB for six bills Canadian!!!
Bikersmurf
The F series frames are significantly narrower that the van frames, don't know it matters, but mounts would need to be custom.
Could you bolt in a tank like those in an E350 Ambulance? They are 35+ gal and mount behind the rear axle... Not sure which all cut away vans had them.
QCAuto
Narrower is OK, makes easier to install lol. Forgot about the cutaway, my deck truck had a large rear tank
Tdavis8695
