adding an Overdrive Unit on 4r70
bkbroiler00
hey there - wondering if anyone has added an overdrive unit to a 4r70 transmission? i love how the 4.88s do off the line and off road, and not so much how they do on the interstate. is there an overdrive unit that can be added to alleviate the whine and help with mpg? is that possible with the tranny/xfer case our vans run?
thanks!
:costumed-smiley-007
Since you mention transfer case I will have to assume that you have some 4WD conversion, which is not stock. But you would need to know what transfer case you are running to see if any of the normal post transfer case overdrives (like a gear venders) will work.
I am not aware of any that go between the transmission and transfer case. At one time there was a .75 OD option for the 3-speed Stak transfer case but it did not like sustained highway driving. You get a 3:1 low range but they put a 1:4 gear after that. They were fine ina Jeep at Moab that wanted to make the 6 miles of highway to the trail head, but they self destructed if you tried to drive the 400 miles to Moab.
You can get a transfer case with a lower low range and put more highway friendly tires on.
They do make reduction boxes (typically 2.72:1) that go between the transmission and transfer case. That along with more highway friendly gears.
You could regear the transmission itself. The older AOD gearset can be swapped in and the overdrive goes from .70 to .667 (2/3s instead of 70%). But first gear isn't as low.
What you would need are additional gears. Gear vendors? Don't know if they work with a 4x4.
Though mpg cannot be the issue: if you spend 1k into gears or gas doesn't matter.
nahuebsch
