DesertDreaming
We have been overlanding through the west in our 2005 LJ We carry a bit of gear and we also tow an overland trailer that is 800lb empty and 2000 lb fully loaded. We are usually right around our max GVWR for most trips, and occasionally a little over if we’re being honest.
We’ve had the vehicle just over a year now. The previous owners installed a 2.5” lift kit from OME on 31” tires. For the most part we like the setup. However we’ve been on the road a little while now and it’s clear that the shocks are worn out. They are the ARB Old Man Emu Nitrogen Sport shocks that came with the lift. The exact model is 600471 in the front and 60049L in the rear. I know that ARB makes a “light” and a “heavy” set, but unhelpfully they do not list which is which on their web site.
So it’s time to put a new set in and naturally with all the weight I want to get it right. I’m inclined to switch to a new band because I don’t like the way it drives now (even when empty) but maybe a fresh set will be better. Otherwise I’m thinking about Bilstein 5100s which I’ve heard some say they are good for heavy loads. I’d be willing to spend a little more, maybe up to $200 per corner if there is something else that would work better. Any advice is appreciated.
