cpendl
This meticulously built RAM has almost every AEV component they make. This was built over a couple of years by the folks at Mule Expedition Outfitters in Seattle, WA. I can share build invoices so you can see what's gone into this vehicle. I used it for a tow vehicle for an Airstream and also a standalone Overlanding vehicle. More info here. Currently offered at $117k; open to serious offers.
Thanks!
Canopy
Power/Electrical
Thanks!
Canopy
- Norweld aluminum canopy
- James Baroud rooftop tent
- Dometic refrigerator and freezer
- 40-gallon water tank with integrated water pump
- Cox reels retractable hose reel
- UV water filtration system
- MaxTrax recovery tracks
- Apple CarPlay
- AM/FM/SiriusXM
- Peplink BR1 Mini cellular router with external antenna
- ICOM ID-5100A HAM radio
- Wilson cellphone booster
- RV Data satellite system
- Milemarker Hydraulic Winch (with Dyneema line, wired and wireless remote)
- Recovery straps and shackles
- ARB compressor with air chucks on either side of canopy
- Airbags for rear suspension
- AEV front and rear differential lockers (re-geared to AEV specs)
- Switch-Pro switches for accessories
- Exterior Lighting (front light bar, sidelights, rear lights)
Power/Electrical
- Magnum 1,000W inverter
- Yamaha 3000 Watt EF3000iSEB (with 20-gallon fuel tank)
- Battleborne lithium battery for canopy
- Cox retractable electrical reel with SmartPlug
- Secondary, high-output alternator to charge Volta battery system in the Airstream
