NorCal 3500
Installed by AEV and removed for different set up. Essentially brand new.
Asking $450
New $550.
Will work with any pick-up bed.
Located in Redding, CA
Occasionally go to Sacramento once a month or so as an option for delivery.
AEV’s Vertical Spare Tire Mount is a vehicle specific solution for securing your full-size spare in the bed of your Jeep Gladiator, HD Ram truck or Colorado. Each vertical spare wheel mount is fully adjustable to accommodate a range of tire sizes and features a robust tubular steel frame that securely attaches to both your truck’s forwardmost bed rail and the floor of the bed to safely hold your oversized wheel and tire in place, even on the roughest off-road terrain.
AEV’s maximum recommended tire sizes for each application are as follows:
Please note: If you are using an aftermarket wheel with a hub bore larger than 3 5/8″ with the Ram Vertical Tire Mount, we recommend also purchasing Wilco Off-road poly cone part number# UC60702.
KEY FEATURES:
Asking $450
New $550.
- 2019+ Jeep Gladiator: up to 42×14.50
- 2003+ HD Ram: up to 42×14.50
- 2017-2022 Colorado: up to 37×13.50
KEY FEATURES:
- Available for HD Ram, Jeep Gladiator and Chevy Colorado AND MORE
- Vertically mounts your full-size spare tire securely in your bed
- Robust, tubular steel frame designed for off-road use
- Adjustable to accommodate a wide range of tire sizes
- E-coated and powder coated black finish
- Proudly made in the USA
