KevinMLee
Wannabe
Hey guys, so I couldn't figure out the difference between Air lockers and the factory lockers. What are the advantages? I've tried to search the forum but it didn't turn anything up for that. My '96 fj80 has factory lockers and since I'm dumping so much money into this build, I wanted to make sure I at least looked at everything. I was looking at the ARB Airlockers and I know I have factory lockers, so I was curious to the advantages of both and should I invest in the ARB lockers.
Also, I've been searching for a "how to" in installing a Warn M8000 winch onto an ARB to no real help for what I need. I've heard mention of taking the planatery cover off and "clocking" it from the 12 o'clock position to the 5 o'clock position (assuming that 6 o'clock is the down position in the direction of the mounting feet. those of you with M8000's, does that mean actually taking off the cover with the hex screwheads and literally moving it to the 5 o'clock position? Or what position is best that will allow me to access the clutch easily? Also, is there anything I should watch out for as I'm doing this? Sorry if this sounds dumb but I wanted to make sure I'm getting this right, since the winch may save me one day.
Thanks Guys
My truck is a 1996 FJ80
Thanks Guys
