Call me crazy, or maybe inspired...
Alaskan Camper just announced a new smaller design for mid-size trucks like the Toyota Tacoma. The camper is 76 inches long, and weighs about 1000 lbs with water and propane on board. The camper is designed to fit in the bed of the pickup, with the door at the rear bumper.
Now for the crazy part. How about mounting two of the new Mini campers side by side on the bed of a Fuso FG, with the camper doors facing the passenger side of the vehicle?
One camper would be for sleeping and storage, the second for cooking and a minimalist bathroom. Or use the second unit as a garage for motorbikes or an ATV. Or set up the second unit as an office. Or a kids' room.
Alaskan Camper will modify a Mini to your design, so you could make the interior to match the way you want to use it. Alaskan will build a camper for use on a flatbed, making extra storage space out of the cutouts that normally fit over the wheelwell in a pickup bed.
The dimensions of the Alaskan Mini show it will fit sideways on a Fuso FG. The cab on the newer FGs is 78.5 inches wide, while the camper is 76 inches long.
Looking at the head-on photo below, I'd say the Mini is no wider than the Tacoma in the photo is, or about 75 inches. So I'm estimating the length of two Alaskan Minis set side by side on the Fuso to be 75 + 75 = 150 inches. The distance from the Fuso cab to the end of the frame is 157 inches, so you might be able to find a place for a spare tire or fuel cans behind the cab, above the transmission.
So why even consider such a wacky idea? First, it puts the entry doors to the campers on the side of the vehicle. A door at the rear gets very dusty and muddy, and you can't help dragging all sorts of crap into the camper when you get in an out of the camper. A side entry is much cleaner.
Second, I like the Alaskan Camper's pop-up hard side camper design and proven strength.
Third, one Alaskan Mini cost $13,000, so two = $26,000. That's inexpensive compared to a Fuso custom camper solution.
Fourth, two Alaskan Minis will weight about 2000 lbs, that's quite light.
Fifth, the two campers would be less susceptible to damage than a single long camper as the truck frame twists over uneven terrain.
Sixth, Alaskan will customize the Mini to meet your needs.
Maybe not so crazy after all, eh?
Thanks to forum member David_in_TX for letting us know about the Alaskan Mini. See his post and the discussion about it here
http://expeditionportal.com/forum/showthread.php?t=24538
See details and more photos in Truck Camper Magazine
http://www.truckcampermagazine.com/index.php?option=com_content&task=view&id=723&Itemid=34
Chip Haven
Chip Haven
