All-Pro links, Walker Evans Coilovers, springs...
bkg
All parts originally on All-Pro's project "TacoSupreme." Truck underwent some changes and finally getting around to getting the barn cleaned up. All parts are located in Middle, TN. While I'd prefer not to ship, I'll certainly do so on your dime!
Nearly everything you need to SAS a 1st gen Tacoma - Throw brackets and shock towers at it, and you're all set!
Links: $200
Lower links are 24" end to end with standard and reverse threads. They are 1.75"x.250 DOM and feature rebuildable Johnny Joints. Each joint is VERY tight and likely do not need service (one jam nut missing - see pictures). The upper link is 30" and the same 1.75"x.250, also with standard and reverse threads, and features 2" FK rod ends. Rod ends are very tight.
Buying these new from All-Pro would run $229 for the upper and $338 for the pair of lowers for $560 plus shipping. The lowers now come with Trail Gear Creeper Joints instead of Johnny Joints. This is a great starting point for a solid axle swap!
https://www.allprooffroad.com/shop/sttel-lower-links-sas/
https://www.allprooffroad.com/shop/upperlink-w-heims-sas/
Springs: $200
"rear springs for 98-04 Toyota Tacoma. These are from All-Pro Offroad. They were replaced by a new set of All-Pro springs thinking these were worn and sagging after over 10 years of use. The new springs provide the same ride height, so the old springs show very little sag.
All-Pro has these listed for $550... plus shipping. https://www.allprooffroad.com/shop/1995-2004-tacoma-leaf-springs/
NOTE: in the pic, the lower spring is the correct spring. The upper spring is an 05-15 rear spring for reference.
Coilovers: $525
For 12" Walker Evans coil over shocks. Remove Reservoir with adjustable compression valving. Includes Eibach 175# (pn 206446) over 250# (pn 223664) springs and added on-shaft bump stop. Shocks were rebuilt by Essentially Off-Road in 2013 (I believe), revalved and recharged. Since then, they have seen < 2000 miles.
One set of eye bolts included. Eye to eye extended length is 31".
Currently still for sale, the shocks will run $360 each, springs running $120/each (x2)... for about $600/corner.
http://walkerevansracing.com/products/13-performance-25
https://www.allprooffroad.com/shop/eibach-springs/
00B0B_bwyU1DrXBTV_1200x900.jpg00F0F_hrzCkWoanDZ_1200x900.jpg00L0L_aNwAWNoRQU5_600x450.jpg00L0L_9CllZPm9C71_50x50c.jpg00C0C_6dawB2caTtY_600x450.jpg00A0A_2Kqswm2OxeX_50x50c.jpg00T0T_6stGIQfBh00_600x450.jpg01212_3Pl803qGERY_600x450.jpg00B0B_bwyU1DrXBTV_1200x900.jpg00F0F_hrzCkWoanDZ_1200x900.jpg00L0L_aNwAWNoRQU5_600x450.jpg00L0L_9CllZPm9C71_50x50c.jpg00C0C_6dawB2caTtY_600x450.jpg00A0A_2Kqswm2OxeX_50x50c.jpg00T0T_6stGIQfBh00_600x450.jpg01212_3Pl803qGERY_600x450.jpg00B0B_bwyU1DrXBTV_1200x900.jpg00F0F_hrzCkWoanDZ_1200x900.jpg00L0L_aNwAWNoRQU5_600x450.jpg00L0L_9CllZPm9C71_50x50c.jpg00C0C_6dawB2caTtY_600x450.jpg00A0A_2Kqswm2OxeX_50x50c.jpg00T0T_6stGIQfBh00_600x450.jpg01212_3Pl803qGERY_600x450.jpg00B0B_bwyU1DrXBTV_1200x900.jpg00F0F_hrzCkWoanDZ_1200x900.jpg00L0L_aNwAWNoRQU5_600x450.jpg00L0L_9CllZPm9C71_50x50c.jpg00C0C_6dawB2caTtY_600x450.jpg00A0A_2Kqswm2OxeX_50x50c.jpg00T0T_6stGIQfBh00_600x450.jpg01212_3Pl803qGERY_600x450.jpg00B0B_bwyU1DrXBTV_1200x900.jpg00F0F_hrzCkWoanDZ_1200x900.jpg00L0L_aNwAWNoRQU5_600x450.jpg00L0L_9CllZPm9C71_50x50c.jpg00C0C_6dawB2caTtY_600x450.jpg00A0A_2Kqswm2OxeX_50x50c.jpg00T0T_6stGIQfBh00_600x450.jpg01212_3Pl803qGERY_600x450.jpg00F0F_hrzCkWoanDZ_1200x900.jpg
