Alternator choices
gtbensley
My van recently started not charging at times after start up. Alternator would load up, batter light would come on and the volts would remain low. I believe it must be something in the alternator, stock 1995 7.3 ambulance with 156k on it. Removed the alternator last night and determined its a Mitsubishi 215amp monster alternator with dual internal regulators.
Not sure I need to replace it with such a beastly unit, I don't run a whole lot of electronics (read expensive to replace). The local parts store has a rep lament coming for me, but it's a 165amp leece nivelle not the Mitsubishi. I found this article talking about alternators, that unit should work correct? My alternator is the first one the gentleman lists.
Stollen from dieselworks forum.
I've got a bit experience with alternator stuff. Just finishing a heavy-duty alternator install. Hang in there, this might get kinda long.
If the amb. package is aftermarket as you mentioned, it probably has one of three different alternators.
1. Mitsubishi 215-Amp dual-rectifier, brushless
Factory heavy-duty, Ford E & F series 7.3L Vans & Pickups and some commercial cutaway chassis under EMV and shuttle buses.
Reference part #'s A8TU0091, F5UU-10300-CA, GL-360, Lester 12075
Regulator: OE 33-Amp Field Current device, aftermarket reg w/60-Amp Field Current device, part #IM840 from dealers for www.transpo.de. Transpo regulators are all over US, just find a auto electric shop and ask for part # above. Same for diodes.
This alt. is pretty hard to disassemble. No service documentation available...I looked for the longest time. Way expensive to get serviced.
Romaine Electric in Seattle charges $450-500, Seattle Fire and City Light trucks have a few repaired each month.
Cheap in wrecking yards, search Car-Part.com--Used Auto Parts Market.
2. Penntex Industries, dual-rectifier, brushless
PX-220P-5 1988-92 201 amps
PX-220T-5 1992-94 208 amps
PX-520T 95-03 208 amps
PX-627T 95-03 280 amps
PX-635T 95-03 350 amps
All documentation on parts and servicing is at PennTex Industries, Inc.. Easy to service with info from their website.
3. Leece-Neville, brushed models
Case for 7.3L
A00190745 1988-1998 165 Amps
A00190762 1992-1998 165 Amps
A00190770 1992-1998 165 Amps
Ford E/F trucks in 80's and early 90's. Very popular in marine world. Some documentation available at Prestolite Electric Inc - Global Home.
The latter two companies make very tough alternators and LN's can be externally regulated without much modification, penntex are all external regulated. Unfortunately, these alternators are quite expensive. So if you already have one great...otherwise, they go for $500+ new...or start a hunt on evilbay.
I'm using a Penntex PX-520T with an 3-stage external regulator to charge 4 trojan T105 deep-cycle batteries (400ah) plus the 2 stock batteries. This unit outputs 106 amps at idle. The two batt banks are isolated via solenoid controlled by the external regulator. Alternator sizing is done with the 25% rule...total amp-hours of all battery banks multipled by .25 = alternator amp output. Also, remember to use hot output ratings as most OEM alternators are rated cold (advertised output)...3-stage regulators can smoke them, easy!
Bikersmurf
Your easiest option would be to order annother Mitsubishi 215 Amp off ebay. Other than that, you can likely fit any alternator that came on a 7.3. The hard part would be finding one with an 8-groove pulley, and the mounts to fit your block.
When I Asked at Ford, they were $859, and had no stock in North America. NAPA didn't have stock but could rebuild mine for about $450... It was the same story with the other Jobber Parts stores. Maybe you'll get lucky like I did and find the new one that was ordered six years back and the customer paid or returned.
gtbensley
We have a local alternator and starter company......had one sitting on the shelf and got a great deal on it. Brand new!
Bikersmurf
Excellent news... I did the same, never used OE alternator, $300. It wasn't worth the effort of trying to swap in a different one... And who wouldn't want 215 amps to run a space heater in a pinch. Makes me wonder how many are sitting on shelves even though no one has a listing for them.
gtbensley
I thought the same thing! I was shocked when the sales guy said he had one on the shelf. I had called probably ten other sources and no one could get me one besides Napa which could do a reman.
Back up and running now. Was out with the van all weekend and had a great trip. Did about four hundred miles and another seventy miles of dirt roads on the dual sport.
Mcoleman
