Alu-Cab, Alu-Cabin Camper for 6.5' Bed, $29,500
Thunder Snow
⭐⭐⭐️ This Alu-Cab, Alu-Cabin is the ultimate turnkey overland setup and was built by OK4WD. It fits on any 6.5' truck bed using the truck specific Alu-Cab fit kit, and comes with the 2022+ Tundra fit kit. This rig has the legendary Alu-Cab features and durability, and is ready to install on your truck to start your adventures.
⚠️ NOTE: Camper only. Truck is NOT for sale.
✨ HIGHLIGHTS
✅ Condition: Like-new, original owner, zero defects.
✅ Build: Professionally assembled and installed by the experts at OK4WD.
✅ Compatibility: Will fit any 6.5' truck bed using the truck specific Alu-Cab fit kit. Includes current 2022+ Tundra fit kit.
✅ Power: Pre-wired for Goal Zero Yeti Pro 4000 (Grid, Solar, and Alternator charging).
✅ Climate: Dickinson P9000 propane fireplace for true 4-season comfort.
🏠 THE CAMPER BUILD
🔹 Alu-Cab Alu-Cabin for 6.5' Bed (Black)
🔹 270° Shadow Awning (Driver Side) + Storm Kit & Gutter
🔹 23 Zero Kestrel Shower Cube (Passenger Side)
🔹 Alu-Cab Table Slide + Matching Alu-Cab Aluminum Folding Camp Table
🔹 50L (13.2 gal) Internal Water Tank + Gravity Spigot
🔹 Full Mozzie/Midge Net Kit (Rear door, side doors, large doors)
🔹 Pressure Roof Vent with cover
⚡ ELECTRICAL & LIGHTING (sPOD Controlled)
🔹 sPOD BantamX: Bluetooth touchscreen digital and app control for all accessories.
🔹 Baja Designs Lighting: 360-degree lighting (Squadron Work/Scene pods on sides and rear).
🔹 Solar: 200W Fixed Solar Panel on 1450mm Load Bars.
🔹 Shore Power: Exterior NOCO 110V plug-in.
🔹 Pre-Wired: Goal Zero Escape Drivable Kit (Plug-and-play for Yeti Pro 4000).
🔥 HEATING & PROPANE
🔹 Dickinson P9000 Propane Fireplace (Dry heat, no condensation).
🔹 Expedition Essentials Quick-Release Propane Mount.
🔹 Exterior Propane Quick-Connect Port.
🔹 10 lb LPG Cylinder included.
🛠️ EXTERIOR & STORAGE
🔹 Molle Corner Plates (Full size, Black).
🔹 Maxtrax Uni-Latch Kit V3 on rear door.
🔹 Push-button side door lock covers.
💰BUNDLE OFFER: $32,500 for the camper + the Other Available Options listed below.
📦 OTHER AVAILABLE OPTIONS:
❄️ National Luna 90L Fridge: Stainless Steel Legacy Series ($1,200)
⚡️Goal Zero Yeti Pro 4000 (New): 315 Ah Battery + Mounting Plate ($2,500)
🪏 Maxtrax Recovery Boards: Grey Set of 2 ($250)
📍 PICK UP/TRANSFER: Contact me for options.
📲 Call/Text: (716) 523-9321
📩 Email at tlclever@gmail.com for more photos, build invoice, measurements, or walk-around video.
jgwarren319
