Alu-Cab Canopy Camper for 5’ Bed - Cincinnati Ohio
EscapeplanUSA
Selling a well-outfitted Alu-Cab Canopy Camper (3 years old) for a 5-foot truck bed. This build includes a fitment kit for a third-generation Tacoma 5-foot bed (other models are compatible with an additional fitment kit).
The camper has been gently used, always been garaged, is pet-free, and has never been smoked in. It is designed for true off-grid and all-season operation, with all systems professionally installed and optimized for simple use by NutHouse Industries in Morrow, Ohio. Bring your truck to this expert Alu-Cab installer in the greater Cincinnati area for professional installation or arrange to trailer the camper to your destination.
Cost: $16,500
Camper Only – Truck not for sale
No Trades
All travel and installation costs are the buyer’s responsibility.
Camper Build:
- Alu-Cab Canopy Camper (installed on truck for the last 3 years)
- Fitment kit for third-generation Tacoma with a 5-foot bed
- Alu-Cab Shower Cube and Deflector Mount
- Alu-Cab 270 Shadow Awning with Deflector Kit
- Alu-Cab awning back door gutter
- Alu-Cab full awning side wall kit with bag
- Alu-Cab table slide with mounted aluminum table
- GP Factor rear door table with slide-out cutting board
- Alu-Cab rear molle panels x2
- Alu-Cab screen and shade packs (side windoors and rear door)
- Alu-Cab water tank (Never used, Not mounted or plumbed)
- Windoor lock covers
- Stealth Nutzo lockable MaxTrax box with easy access door (MaxTrax not included)
- 20L Whelan jerry can with mounted rear door holder
- GP Factor inside rear door molle panels
- Rollercam door assist strap
- Expedition Essentials 11 lb propane tank holders x2 (lockable)
- 11 lb powder-coated propane tanks x2
- 4thD 360Watt roof solar panel
- Redarc Manager 30 (DC to DC, solar controller, shore power, BMS1230S3R)
- Redarc RedVision display
- RedArc Pure Sine Wave Inverter 1000W 110V GFI outlets
- Garmin power switch
- Vision X amber Dura Mini floodlights (amber, rear mounted)
- Propex 2100 high-efficiency propane furnace with thermostat
- DeemerBox DB2 speaker with quick release rear door mount
- Modular custom furnace and battery boxes (Tacoma 5-foot bed only)
- 100Ah Battle Born batteries x2
- External shore power connector
- Original mattress has never been used
- Full BedRug for Tacoma 5ft bed
I don't have an exact weight, but maybe around 850-900. I don't run anything exotic for suspension on the truck beyond rear Bilstein 5160s with some Firestone airbags set at 30-50. I've never had a handling issue even with gear on top of that. Just note, I never used the water tank so that would certainly add weight when full.
The solar panel is extremely low profile. This panel was designed for harsh use but without adding extra height or bulk. with about 200 times more interconnects of similar panels making it more durable. The manufacture claims 80% lighter and 50X more durable that competitors. Not sure about the marketing but they perform now like they did day 1. If you need more photos let me know and I can provide them.
The side walls have never been used and have a dedicated bag with the instructions on how to assemble. It really increases the footprint around the camper, there are pictures online that may give you a better idea.
DETN8
