Interested in knowing if anyone has tried mounting a CVT like RRT on top of the Alucab canopy. CVT tent comes with two rails with T slots to slide in brackets. I believe the canopy also has T slot rails that run on the outside edge parallel to the bed. Since the rails for the canopy and tent run perpendicularly and don’t intersect, I don’t think they can be mounted to each other. Only other thought would be to get the alu-can load bars that also have T slots and see if the bracket plate would be wide enough to bolt around the cross section. One way would be to rearrange the rails to run them parallel and somehow join the two rails together. Not sure if there is a part to do this. Any suggestions to mounting that would be least troublesome for single person mounting?
