Ambulance electrical
chrisquested
With these ambulance having so many wires would I just rim out all these circut boards, relay, and junk ?
I just want basic wiring such as head lights and stuff as for the outside led off road lights I can re wire that in and also wire in the led interior light?
Abitibi
Each ambo is wired somewhat differently. On mine I got rid of all the circuits I didn't need, kept the one that had a purpose and re-use some of the components for new gears.
I've kept the HD solenoid, battery charger + isolator and the inverter since they are well built and useful.
You can check what I did in my build although I'm not done yet. It should still give you an idea of what's involved.
Good luck!
Mr. D
Ozrockrat
Yep they are all different but usually well marked and mostly isolated from the "normal" electrical. I would suggest that you follow the previous posters lead and work out what you need where before stripping it out.
I didn't modify any of the wiring on my last ambo. But this one will be different, I need to free up some space for the solar controllers and 110 and 240 panels. this panel is on the outside of my rig and is at least 3' x 3'.
chrisquested
yea I will be getting mine this weekend its a 1989 E350 or E450 it has the 7.3 diesel.
Got to figure out how to put a water tank, tankless water heater, 2 propane tanks, solar panels and generator, as for cooking I am going to use a gas/wood drill to bbq. I will keep browsing the side and get ideas.
bdog1
Man! That's a lot of wiring! But you gotta give it to them, it's clean.
Sent by wing, prayer & ATT
gringorick
I removed some of the wiring, but left the guts in place in the main control panel. It seemed that every time I removed a wire from one item it affected another needed item. Since I am on a time crunch to get a home built for a February SA departure date, I elected to not open too big of a can of worms. But I bet I could strip 100lbs of copper out of that thing if i really wanted to. I pretty much re-used most abandoned circuits for something else anyway.
Now, if I could only figure out how to get my stock horn working again...
chrisquested
Wow I removed one trim piece and there was a ton of wires! I am thinking this ambulance has less wires than most of the other one because it's older?
Tdavis8695
