^^ X2 I've seen them tucked behind the corner loom, usually Toyota uses white or green tape (with notches in the edges so it tears easily) to secure an unused harness. The plug itself may not be immediately visible but the tape should be easier to find.
On my Tundra the plug is at the top of the drivers side kick panel. Removing the panel is not needed. Not sure if the plug is in the same location on a Tacoma.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
