Broncos suck!
- the TTB eats tires for breakfast. SAS is easy enough though. The extended radius arm TTB kits do make a difference in the positive direction, but tires just don't have much of a chance with the camber changing constantly.
Common misconception here... If you know how to PROPERLY set-up a lifted TTB system you can get the articulation/stability/tire wear of any solid axle rig, along with the comfort of a "true" IFS rig... Getting all the geometry right IS a little more work, but in the end the TTB is superior (IMO) to any other suspension system for the here intended purposes...
The width is a pro and a con. It improves stability with a short wheelbase and tight turning radius but could be unfriendly to Jeep size trails. I would rather have the extra width, interior space, capacity and stability.
TTB is pretty good with a mild lift and extended radius arms.
As I've stated befor eon this topic, the quality of the damping is solely responsible for this urban legend. Put cheap shocks on an otherwise sound TTB and you'll get those results. Put quality monotubes on it and you will not.Common misconception here... If you know how to PROPERLY set-up a lifted TTB system you can get the articulation/stability/tire wear of any solid axle rig, along with the comfort of a "true" IFS rig... Getting all the geometry right IS a little more work, but in the end the TTB is superior (IMO) to any other suspension system for the here intended purposes...
My .02...
The bronco is a great platform as you get a solid chassis, good motor/tranny selection, a good wheelbase with good maneuverability, and a great aftermarket. Solid axle swaps for the TTB are super easy if you go all out. Rear suspension mods are very easy. (i.e. shackle flip)
There are some cons though...
- they are wide, but they do turn sharp.
- two doors get old.
- top is removeable, and soft tops are an option, but the top is HEAVY. Not a five minute job.
- trying to find one that isn't completely clapped out is a challenge...but that seems true of many desirable expo platforms these days.
But parts are super easy to find (same as F150) and they just aren't too hard to expo out.
and a super-runner steering will keep the bumpsteer and alignment much nicer..
Honestly, that Superlift Super runner steering is garbage. You're better off keeping the stock y-setup.
