Hi Sean,
Welcome to the forum. Most people around here have a decent understanding of lead-acid batteries (and solar->lead charging), and most have seen the comparisons between lead and lithium. So putting any sort of sales spin on your posts could end up being counterproductive. Straight up tech talk will be highly valued. Also keep in mind that there are some engineering types around here who will check your numbers to see if they add up.
When it comes to lithium "drop-in" replacement batteries for deep cycle use, the great mystery is the BMS. Knowing precisely how it operates will be a major boon to those trying to make a decision to move to lithium.
For instance, as I mentioned in a previous post on this thread, the FAQ on the Battle Born site says to bulk at 14.4v and float at 13.6v. These are obviously the numbers for a typical lead-acid charging setup, and it makes sense to use them to reassure buyers that their existing system will work with the lithium drop-in replacement.
BUT...for people who understand batteries and charging, it is, as I said, baby talk.
So...
What exactly is the BMS doing? (Technical details please - assume we've already read the marketing materials.)
What is the actual full charge voltage of the battery?
What is the perfect charge voltage?
I.e., if the cells total up to say 13.8v, what is the BMS doing when the supply voltage is over 13.8v? Regulating the voltage internally, obviously, but how? PWM fast-acting chatterswitch or what?
Sure, existing tech will work, but for those with expensive and sophisticated fully programmable systems (not me, I'm just a gadfly), what exactly would be the perfect programming to make your batteries most happy?
Knowing exactly how the BMS behaves is crucial to figuring out how to integrate the drop-in replacement to an existing system - for example a system based around a battery to battery charger such as a CTEK or Sterling Power Products (both popular around here), or a system built around an automatic connection relay (ACR) such as those from Blue Sea, National Luna and Samlex, or even just a dumb ignition-controlled split-charge relay.
And that doesn't even touch on dialing in a programmable solar charge controller. "Enquiring minds want to know."
The next most common concern would be temperature. Aux batteries used in "overlanding" can see some temperature extremes at both ends of the scale. The FAQ says your BMS protects the cells from low or high temps.
How exactly?
(Obviously, that is not the same as the "temperature compensation" that solar charge controllers do for lead-acid batteries, but people could easily confuse the two.)
What are the temperature set points programmed into the BMS, and what exactly does the BMS do when it hits those set points?
I'm sure there will be lots more questions. You might keep in mind that this forum has well over 100k subscribers, most with disposable income, and at any given moment there could be more than a thousand lurking and browsing and learning, even if only a few of us are posting.
Cheers.
