ARB Firewall Fitting
RocKrawler
Supporting Sponsor
Have you ever wanted to mount your ARB compressor inside the vehicle or in a protected compartment & run an ARB airline through the firewall, floor or other steel panel? Worried about a grommet wearing through and the line getting chafed or worn through and causing a leak? Iron Pig & 4x4 Connection now have the ARB splice kits in stock along with the hard to find jam nuts necessary to make the perfect through fitting in your panel! Now you can install your compressor in a protected area and never have to worry about a cut line from the metal it has to pass through to get to the chassis & axles.
Kit includes 1 ARB splice fitting and 2 jam nuts for only $15.95, installation is a snap; just drill a hole & install, press in your air lines and you're done! Give us a call to place your order at 866-IRONPIG
Clemtiger84
