ARB fridge install
badtoytrd
Mountain Lover
I started my build thread yesterday and I wanted to add the write up for my ARB fridge. I wanted a fridge that I could fit behind my seat and still be able to adjust it. The fridge is probably the best investment I have ever made for my vehicle. I bought it for when my fiancé and I moved across the country from MD to WA. I wanted to be able to stop at a grocery store every couple of days and stock up on food instead of eating out all the time. Boy, did it work perfectly!
Now on with the build.
Parts needed:
ARB 37QT Fridge Freezer - http://www.sierraexpeditions.com/index.php?l=product_detail&p=2205
ARB Fridge Freezer Wiring Loom - http://www.sierraexpeditions.com/index.php?l=product_detail&p=2290
- I could have used some duplex wire but I ended up buying this kit. I had a problem with the 12v style plug making a proper connection and because of that it kept blowing fuses. The below fixed the issue.
4 pin trailer plug - http://www.etrailer.com/dept-pg-Wiring-sf-Trailer_Connectors.aspx
- I used a 4 pin just because it was readily accessible.
To install it all I removed the moulding along the rocker panel and next to the emergency brake and ran the duplex wire where the moulding was to my aux fuse block. I also removed the cubby under the rear seat, drilled and hole for the plug and installed it. I also cut the 12v plug that came with the fridge and soldered and applied heat shrink to the fridge side connector.
Plug in cubby
Plug to fridge
Soldered plug with heat shrink
Wired to fuse block
Fridge in location
Petersmithinak
