No, I,m running stock Rubi lockers, but the compressor comes ready with harness to hook right up to the solenoid and switches of the ARB Lockers. My cost here in Canada was $500. This is a very well built unit, very well sealed to the elements and 100% duty cycle. Puts out over 6cfm at 0psi and puts out about a very decent 4.5cfm at 30psi.Questions: Are you useing the compressor to run your lockers, also. If you don't mind, how much? I have front and rear air lockers and was thinking on going with the Puma.
Thanks, Ron
