Fits a 5' bed 1995-2025+ Tacoma , and GMC canyon and Colorado
Habitat is in great condition. Has a Water tank mounted to one side, with a pop out shower tent, and an 8' awning on the other side, with mounts for 4 gallon Rotopax fuel tanks. Has aluminum L track all around the habitat, both interior and exterior sides as well as the roof. Habitat comes with the factory mattress as well as a high end self inflating mattress called an Exped megamat.
There is a full shower setup on board, with tankless water heater that connects to the propane tank via quick connects, and is designed to either used the existing water tank on the exterior of habitat, or even better if you can park within 50 feet of a water source you can take an unlimited in length hot shower via a pump / filtration system that is also included and designed to run off the battery in habitat.
Custom made rear swingout kitchen setup, Designed to retain factory license plate and usability of rear hitch. This also have a 2'' receiver built into it at the top which allows for carrying other hitch accessories like a mountain bike rack, cargo carrier etc. Also has a bracket to carry a trasharoo. The rack also holds the included Worthington 6lb aluminum propane tank with an aluminum mount. As well as shovel / axe combo.
Prinsu roof rack, with rifle case for recovery gear / etc. Mounted on top of the rifle case is a 100w solar panel , rack also has a 40'' light bar.
The interior of habitat has a custom aluminum battery box that also holds the solar control module and 12v power station to hook up a fridge or other 12v accessories. There is also a diesel heater that is mounted to top of the aluminum box. There is a Renogy rover charge controller to hook to your vehicle alternator to charge while driving included brand new in box.
Im sure there are some things I am forgetting that will come with it.
A habitat spec'd to this one is over $15k for the camper itself if bought new, I tried adding parts up and to build this same setup would be around $23k today
$12,750 for the whole setup. May trade for other cool stuff.
The truck + camper is also for sale listed in the vehicles section but at this point Id kind of rather keep the truck and sell the camping accessories.
