Autarky flatbed aluminum camper - Lightweight 4 season ready adventure cabin. Outfitted for full time overland travel - Ready for your truck.
dcrzach
This Autarky Flatbed camper is now being offered for sale as an individual unit. Designed to fit on CM flatbeds aluminum 8 foot flatbed (can be adapted to work with a variety of other manufactures) - This showroom unit is ready to mount on the full size truck of your choice.
The camper was built from the ground up to be as light, strong, and well insulated as possible. The full aluminum core structure is both lightweight and weather resistant. The camper has a 3-part insulation system involving butyl sound dampening materials mixed with a Thinsulate core. The result is a highly insulated structure that makes even the windiest stormy nights on the road just as peaceful as the calm ones. The camper features a timberline diesel powered hydronic heat system that provides both hot water for showering and the thermostatic heat source for the camper (both underfloor radiant and ducted vents). The highlight of the kitchen is the marine grade wallas diesel cooktop and the low power draw DC fridge/freezer. A hidden toilet stall slides out from below the cabinetry revealing the trusty Thetford curve cassette toilet. Folding down from the opposite side of the cabinets is the easy-to-use tetra van shower stall. With 35 gallons of insulated fresh water onboard and 800w of rooftop solar, this camper was designed to travel great distances to extreme remote places. The camper also features Cruise n Comforts coveted DC powered air conditioning system for travel down south. The camper is easily lifted on and off the truck of your choice, utilizing the remote control deployed Reco Titan lift jacks. Spare tire carrier / rear entry steps and deck designed for Ford Superduty truck is included with the camper. Ready for your next adventure? Contact Zach (775-200-3591) to see the camper is person- Available to be seen at the Autarky storage lot in Fallon Nevada.
Listed at $80,000 - Available to be seen now in Fallon Nevada! Call Zach 775-200-3591
The Camper
  • Full aluminum welded frame construction (frame core photo attached)
  • Riveted and Sikaflex adhesive exterior aluminum skin panels wrapped in 3m vinyl w custom design.
  • 2in of closed cell foam insulation on all walls and roof
  • Insulated aluminum subfloor with underfloor hydronic heating
  • Rico Titan Electric Automatic camper lift system with remote control
  • Custom CAD designed rear spare tire carrier/ entry steps and landing.
  • Marine Vinyl insulated woven flooring
  • Marathon Tweed Grey Heather insulated/cushioned interior wall panels
  • All Custom lightweight Birch and Bamboo cabinetry
  • Indel B Marine 12v fridge/freezer
  • Wallas Diesel Cooktop
  • Push/Twist latching storage compartments with Froli Cabinet organization system
  • Stainless Terra Van Custom Shower Stall with Skandvik Faucet
  • 1000lb drawer slide Toilet stall with Thetford Cassette Curve toilet
  • Dinette Seating with flip up bamboo table
  • Fixed over cab King size bed with 4in luxury memory foam mattress
  • Custom made matching marathon tweed Dinette cushions -converts to additional sleeping area for 1
  • Complete soft white Redarc controlled lighting system with RGBW under cabinet mood lighting flushed into aluminum trim accents – with touchscreen controller
  • Max Fan- Rain sensor and remote control
  • Various Interior 120v GFI Dual outlets along with 12v USB charging ports
Power System
  • 800W Spartan 200Wx4 Rooftop Solar array
  • RedArc TVMS Bluetooth Charge controller and Victron 100/50 Smart
  • RedArc BMS with Shunt – Interior controller
  • 1500w Compact Cotek Inverter
  • 200 Amp DC disconnect
  • 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
  • 400ah Lithium Battery bank
  • Anderson quick disconnect to truck – Charges house batteries while driving via red arc TVMS system.
  • Exterior 120v weatherproof power ports
Water, Heat ,Cooling
  • 35 Gallon Fresh water tank – SS marine inlets
  • 15 Gallon Grey water tank
  • Pentair 12v Water pump controlled with RedArc Main panel
  • Timberline Hydronic System. Provides instant hot water/ Heated flooring/ Thermostat controlled air exchanger heater. All Diesel powered via external rear mounted fuel tank.
  • All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
  • Maxfan Deluxe
  • 12v Sirocco 2 Cabin fan in bed area
  • Cruise N Comfort HD12
Asking price is $80,000 -
TNielson-18
