AutarkyEV Offgrid 4x4 Expedition Vehicle F450 Ambulance Conversion - SOLD
dcrzach
V3 is back for sale! V3 was completed in 2020 and sold to its previous owner. The previous owner Andrew took his family on multiple US expeditions and ultimately worked their way down to the Mexican Yucatan peninsula. They traveled and lived fulltime for nearly a year living the dream before returning to the states. They have finished their travels for the moment and have brought the truck back to Autarky headquarters to prepare it for sale. The truck has been tastefully upgraded by its previous owner and has been maintained with exceptional care. The truck is clean, prepared and ready to go on its next expedition.
The Truck was designed around extreme exploration and ultimate comfort. With a proven global track record the Diesel powered Ford Superduty platform was our first choice. We acquired a low mileage 4x4 F450 Ambulance in Denver Colorado where we proceeded to drive the truck back to our shop/home in Reno and begin its conversion. The ambulance was stripped down to its aluminum core – Completely re–engineered/Cad Designed/ and professionally rebuilt into the camper you see today. Instagram Handle - AutarkyEV
Price - 140,000$ Contact Zach at 775-200-3591
The Truck –
  • F450 Superduty Cutaway
  • 6.0L Bulletproofed Powerstoke diesel – Just rebuilt 10k miles ago from the block up by McDiesels of Reno and Tuned By Desert Diesel of Phoenix – New Heads, Complete Gasket Kit, HPOP, EGR Delete, Sinister Diesel Oiler cooler , Custom tune No DEF - Diesel 2/ biodiesel/ - no low sulfur required - ready for global travel.
  • 2003 , Single Cab, ambulance conversion
  • Purchased with roughly 85,000 Miles , Sold to initial owner at 90,000. currently at 107k
  • Custom Vesuvius Grey Custom Paint with complete OEM plastics coated in Bullet Liner.
  • Total loaded weight is 12,800 Pounds
  • Total length bumper to bumper is 22FT
  • Total height is 10'8"
  • Fuel economy around 12mpg with loads of highway diesel power.
  • GCWR of 26000lbs. The truck is only 12,800 loaded. That leaves you with a 13,200lbs tow rating
The Drivetrain –
  • 4.88 Gear Differential
  • NV271F Heavy duty transfer case
  • Dana 60 Front Axle with Dana 130 Rear
Suspension, Wheels, Tires –
  • Atlas 4in Over stock Expedition Pack Custom built Leaf Springs front and Rear
  • Buckstop Designs Super Single lift components
  • Icon 2.0 Custom valved Shocks – All 4 corners
  • Bushcwacker Fender flares bullet lined to support 41in Tires
  • 20in 1st Attack Engineering “Super Single” Wheels
  • 41in Continental MPT’s Tires
  • Custom fabricated rear sway bar from Peavine Motorsports
  • Front Hellwig swaybar with extended Links
The Camper –
  • Full aluminum construction torsion free mounted Camper body – Rebuilt from original Ambulance Box - Interior height - 5ft 10in
  • 3m Thinsulate and Closed cell Foam complete insulation of floor, walls, and ceiling- Comfortable far below freezing temps and cools easily in Arizona heat.
  • Heavy duty insulated aluminum storage doors and entry door.
  • Marine Vinyl insulated woven flooring
  • Stainless steel diamond plated entry way / mud room
  • Hardrock maple interior wall panels accented in aluminum
  • All Custom lightweight Birch and Bamboo cabinetry
  • Isotemp Cruise 90 SS Marine 12v /120v fridge/freezer
  • Furrion Induction cooktop 120v
  • Under bed and inside dinette latching storage compartments.
  • SS Custom Shower Stall with Stoett Industries retractable shower doors – Also serves as vehicle pass-through to drivers cab.
  • Starboard Toilet stall with Thetford Cassette Curve toilet with Maxx Fan power vent and LED light
  • Dinette Seating with Teak Nautical custom table
  • Sliding aluminum and Birch bed platform. Extends to a very large bed slightly wider than a queen with full king-size length
  • Custom made memory foam Dinette cushions and mattress wrapped in easy to clean marine vinyl
  • Complete Lumicoin soft white touch lighting system with RGBW bed mood lighting flushed into aluminum trim accents on ceiling – with touchscreen controller
  • Dometic Heiki 3 Skylight – Bugshield and nightshade
  • 5 total Interior 120v GFI Dual outlets 1 with USB C charging
  • 2 12v USB charging stations
Armor and Recovery Gear
  • ARB premium Front full wrap winch bumper
  • Bullet lined Rear bumper with hitch receiver
  • Smittybuilt 17.5k front winch
  • 12k pound heavyduty exterior mounted recovery boards
  • Full aluminum diamond-plate exterior bash guards bullet lined to match
  • Tig welded, aluminum, powder coated above Cab recovery gear storage rack
  • Rear interior below bed mounted Fullsize Spare tire
  • Rear exterior mounted 4.5 gallon Rotopak
Lighting
  • Pair of Baja Designs S2 Pro floods on ARB mounts
  • Hella Rallye 4000 all metal Pencil Beam Halogens
  • Over Rack mounted 40in LED Light bar
  • Custom engraved aluminum interior control switches
Power System –
  • 640W Rec N Peak Rooftop Solar array
  • Victron 100/50 Bluetooth Charge controller
  • Victron BMS with Shunt – Interior controller
  • 3000w Compact Xantrex Freedom Inverter Charger with interior control panel
  • Midnight Solar Baby box with charge controller and inverter breakers.
  • 200 Amp DC disconnect
  • 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
  • 300ah Battleborn Lithium Battery bank
  • LifeP04 Battery Isolation Manager – Charges house batteries while driving / keeps truck battery charged
Water, Heat ,Cooling –
  • 50 Gallon Fresh water tank – SS marine inlets
  • 35 Gallon Grey water tank – 3in RV style outlet
  • Shurflo 12v Water pump and Shurflo macerator pump for shower .
  • Full Pex Plumbing
  • Isotemp 11 Gallon SS water Heater – 700w 120v and heated via the Trucks coolant while driving
  • All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
  • Diesel Eberspacher d2 Airtronics Heater with Pro touch thermostat Contoller. – has separate 3 gallon insulated fuel container
  • Turbokool 12v DC Evaporative cooler
  • Outdoor hand cleaning water Nozzle
Upgrades since 2020 original build sheet-
  • 12v roof mount Nomadic Air Conditioning system
  • Viar Tanked onboard air system chucked to both side of truck
  • Full Ceder TG interior ceiling with upgraded roof insulation for extreme cold conditions.
  • Interior over bed custom storage web net for extra storage during travel
  • All new Interior LED lighting
  • Exterior extended wash hose
  • Commercial 5g multi connect rooftop antenna system(5 cell carriers, GPS, Long Reach Wifi grabber and more)
  • Weboost 5g fixed antenna signal booster
  • Baja Designs exterior rear and entry lighting
  • Custom built rear swing out tire carrier for full size 42" continental spare
  • Extra exterior mount shower stall / bathroom stall (Drops from powder coated metal enclosure)
  • King Suspension custom steering stabilizer
  • Adjustment to rear Leaf Pack to increase rear ride height
  • Custom 2" hitch system with multi carrier bike rack
Autarky Expedition Vehicles 2023 Maintenance:
  • New Front Continental MPT81 tires with spare rotated in
  • Fresh coat of underside rust protection and exterior skirt line x fresh coat
  • Diesel Mileage maintenance and cleaning / inspection of variable vain turbo system
  • Exterior 2 step polish and ceramic coat
  • Truck plumbing and electrical system inspected and verified ready for future expedition
dcrzach
dcrzach
Truck just completed its mileage maintenance at Mcdiesels of Reno. Fresh intercooler boots, oil change, transfer case flush and new wheel speed sensors. Truck runs better than new , pulls hard up grade and is ready for the long adventure ahead. Call Zach to arrange a showing - 775 -200-3591
taunger
