Aux Power for Lighting
JMyerz
I have begun to shoot more and more on location and would love to build a portable power system like scotts. I'm not sure however what I will need to power up to 3 of these lights:
Specifications
Recycle Time (Full Power 117V 60Hz): 2.1 seconds at 100%
Supply Voltage AC: 95-130 VAC 60Hz
Voltage Stabilization: +/- 1%
Modeling Lamp: Max. 275w
Ready Indication: 100%
Fuse: 10A (T)
Sync Volts: 5V
Photocell: On/Off
Modeling Light Power Control: Intermittent, Off or Continuous Full or Proportioned with Flash
Guide Number: 350 (ft./100 ISO @ full power with a 50° Keylite)
Flash Duration (Full Power) T=0.5: 1/600
Flash Power Control: Full to 1/32 (5 f/stops fully variable)
Recommended Modeling Lamps: 250w 120V Halostar (as standard), 275w 120V Photoflood
Flash Tube Assembly: Clear CE-1020 (as standard) UV-Coated CE-1022
Dimensions: 15 1/8(l) x 6 3/4(w) x 5(h)"
Weight: 7 1/2 lbs.
Thanks
Justin
SANelson
