Stroked 550
I bought the Auxbeam 8 gang switch panel
The subject vehicle is a 2004 dodge 2500 cummins.. I ran the main power and ground leads to the battery and the ground to the truck's body that had another ground already to it.
Then I ran the smaller gauge red "ACC" wire with the Fuse TAP to the cigarette plug fuse locations which only get power when the ignition is on
The problem I am having is when I tried 3 different fuse locations either the power is constantly on or there is no power at all to the actual switch panel if I switch the fuse tap around the terminals go in the opposite location
Can anyone guide me in the right direction?
