Auxillary Backup Light-and more....
mightymike
I saw this in a Cabelas catalog the other day:
Light Buster Utility Light
Here's a bright idea to get more light behind your vehicle. The Light Buster is a dual-purpose backup and utility light that plugs directly into any 7-way round wiring receptacle. In back-up mode the 50-watt halogen bulb comes on when you shift into reverse. A utility-mode switch lets you turn it on manually for extra light as needed.
http://cabelas.com/cabelas/en/templates/links/link.jsp?id=0048618523088a&type=product&cmCat=search&returnPage=search-results1.jsp&QueryText=52+3088&N=4887&Ntk=Products&Ntx=mode+matchall&Nty=1&Ntt=52+3088&noImage=0
Looks like a pretty neat idea, as long as your plug was aimed in the right direction and you took it off upon return to civilization. Nice for backing or setting up camp...$30 at Cabelas, $25 at Harbor Freight
And if you are looking for that unique accessory....
No use for machine gun tips.
However, I don't see much use for that plug-in unit either. I can't see it being of any use on an Expedition-Rig. Just drill and put in quality ones.
Seems more like a weekend-warrior grade light for Grandpa Joe hitching to his trailer early Saturday morning to take the boat out on the lake.
I see that unit being lost on a big bump at 70mph because the owner forgot to take it off.
empireoverlandza
