Crookthumb
What material is the Dana 44 axle shafts on a stock Rubicon TJ made from?
front or rear axles ?
The fronts have a Dana 35 u-joint which are problematic with all the lockers turned on and turning with good traction. The rear has issues with the limited slip and the spider gears. (a front unit fits in the rear and is stronger with out the slipper)
There is debate that the stock axles will twist a little before breaking unlike an after market alloy but I never had they sort of joy and changed to 60's (over kill).
Stock wheels and remember to unlock the front and you should not have too much hassle other that some u-joints. maintenance is also key
