Thanks, but it is pretty well baked on there. The logos on the doors I can just peel off with my fingernails.Heat gun, then peel
They are just individual letters.Is it a sticker or raised letters that are adhered on?
If it is raised letters, fishing line can be used to saw them off
Then a 3m eraser wheel will take off the residue easily
Just go slow and keep things cool
Tabs going through what metal?Search "decal eraser wheel" for the pad you are referencing. j
I doubt it is but make sure it doesn't have tabs going through the metal.
The sheet metal on the car. For instance on my F150 I cannot remove the F150 badge on the front fenders because it is attached with an adhesive and with tabs off the back of the emblem that goes through the sheet metal. If those letters are individual, and not one connected piece, then they are probably just adhesive.Tabs going through what metal?
Oh, got it. They definitely don't have tabs.The sheet metal on the car. For instance on my F150 I cannot remove the F150 badge on the front fenders because it is attached with an adhesive and with tabs off the back of the emblem that goes through the sheet metal. If those letters are individual, and not one connected piece, then they are probably just adhesive.
Yes, dental floss or fishing line works well.
