Too late for OP, but I used a SuperStart AGM, Group 31 in my camper for several years. I eventually killed it by leaving the heat on for a few months by accident. The fan would run all night, every night, till the battery was dead, but the solar wasn't enough to charge it completely during the day, and by the time I noticed, it had several shorted cells that I couldn't recover...)
The battery was ~$200 from Oreilly's. They may not have one in stock, but they can usually get it in just a few days. SuperStart is actually a Deka battery, good reputation!
https://www.oreillyauto.com/detail/...2007-nissan-quest?q=superstart+group+27&pos=4
I'm running a couple of old 100Ah Northstar SLA batteries now. I got them for $10 each from a cellular service center. I'm on my 2nd set, and they usually last three or four years. (they're usually about 50% by the time they get to me...)
I would agree that unless your battery is inside, where you can't have it venting, there's not much reason to use an AGM battery over a flooded battery. In a vehicle, especially, AGM is not ideal because most vehicles charging systems run higher voltage than the AGM really wants... My Jeep is the only exception, as for whatever reason, Jeep typically charges in the high 13v range, rather than 14.3 like most others. I have a 11 yo optima that's still showing decent results on the battery tester, though the capacity is down to 50% or so... Charging AGM's at 14V+ constantly is pretty hard on them, which explains perhaps why Alloy might be seeing problems. My GMC would cook an AGM in 12 months I bet!!
