SoCal_80
Hey all and hoping for some expert advise....
I am about to install a Redarc 1225d bcdc in my trailer along with a Battleborn life4po battery, midi fuses, Redarc low voltage disconnect, etc. I will also be running dedicated charge wires from the Land Cruiser to the Redarc in the trailer. Wiring those pieces makes sense to me but i have a question about the existing 7pin trailer wiring coming from the Land Cruiser to the trailer. The 7 pin connector supplies 12v to the old battery....Do I need to or should i disconnect that ? If i do should i leave the ground coming from the truck from the 7 pin connector attached? Maybe i am overthinking things here.... My thought was to remove the 12v coming from the truck but leave the ground.
Thoughts ?
Thank you all!
Sent from my iPad using Tapatalk Pro
Thoughts ?
Thank you all!
