Best Bags for Camera Equipment??
Colorado Ron
I need to purchase some cases for my equipment. Id like to be able to carry most of it in one bag.
I have a
Canon G9
Sony Handycam
Helmet Cam
Canon XL2
Please post your choice of bags and links if you dont mind. Must be able to hold up to expedition travel conditions.
T4Rfun
Pelican is a great choice for ultimate protection in a hard case, water tight etc. But if you're looking for a "camera bag" that is the ultimate and used by many professionals, especially for video and film production, check out Portabrace. Can be expensive, but you won't be disappointed.
http://www.portabrace.com/
TeriAnn
I have a
Canon G9
Sony Handycam
Helmet Cam
Canon XL2
Question #1: how do you plan to use the bag? Throw it into the vehicle & leave it there? Take it on plane/train/ship trips?
If it is exclusively for trips in your rig, I suggest building the box into the vehicle. Less visibility, less opportunity for it to grow legs & best protection.
If you plan to take commercial transport with the gear, I suggest an obviously expensive protective case is a big sign that says "I'm expensive delicate gear, steal me" I'd suggest hitting the second hand stores to look for an older beat up looking hard sided suit case, filling it with foam blocks & cut out for your gear. And get a strap that you can keep around the outside to keep it from popping open. A suit case that says "Low budget traveler, likely with old socks & underwear that may or may not be clean."
I've always been a believer in misdirection & camouflage when traveling with expensive gear. And anything in a portable case can grow legs the second your attention wonders off the bag.
QUESTION #2: Do you tend to use all your gear at one time? Do you tend to take just one camera system when you walk away from your vehicle?
If you want to bring all your gear but only take subgroups away from the vehicle, usually one subgroup at a time, I suggest having multiple smaller hip bags that you can strap to your waist, carry the load on your hips and have both hands free. You can store the smaller break out bags inside a larger container if you wish.
Way back when, I had a big expensive camera gear back pack that held a complete 4X5" field camera system and a complete 6X7mm medium format camera system. Loaded, it was very heavy, bulky, and hard enough to carry any distance that it soon just stayed in the vehicle.
These days I don't try to carry both systems at one time. With the 6X7 system I pick one body, 3 lenses I'm most apt to use, put them into a hip bag, and walk off with a tripod over my shoulder. Sometimes I have the big 300mm lens in its hard case hanging over a shoulder as well.
The 4X5 is a bit more awkward. I carry a bunch of film holders in a strap on hip bag and the 4X5 with its lenses in an old Mac Portable semi hard case slung from my shoulder. And the tripod slung over my shoulder.
Gear I'm not using stays locked away in their hidden inside vehicle locations.
When I'm out walking with gear I try to keep the gear down to what I'll be using and make the gear as compact and easy to carry as I can. My days of carrying everything, just in case lasted only a few trips.
Colorado Ron
Thanks TeriAnn.
Im going to do some filming in Iceland, so everything has to go on the plane. I wish I could figure out how to make it all a carry on, but I cant see that happening.
JackW
I've been using Tenba photo bags for the last thirty years - they're really well made and offer good protection. I think I own about five of them in different sizes depending on how much stuff I want to lug around.
If I'm traveling in my truck I generally use one of the three or four Pelican cases that I have set up to carry camera gear (again different sizes for different mixes of gear).
articulate
Ron, I think you should be looking at a hard case for transporting your camera gear by plane. Like others suggested, a Pelican or similar.
Then use something else, like a soft sided bag, for when you're mobile. Something you can sling around your shoulder, wear as a backpack (I'm not fond of these, but others mike like 'em), etc. Domke and other companies make rugged canvas bags in a variety of sizes with movable interior dividers. Here's a Domke F-2 that I like, but I wouldn't dare pack and then check this sucker on a plane. Pack it in a secured Pelican with the other gear maybe:
Overland Hadley
on a journey
I would say a system of soft cases (for when you are in Iceland) packed inside Pelican cases (for the plane trip) might be a good bet.
Just remember that nobody carries their underwear in Pelican cases, so they could walk away. Plaster the case with "I love knitting" stickers, and it might be safe!
T4Rfun
Pelican 1527
I have one of these as well for my video camera. It's by Pelican and it is a decent size soft camera shoulder bag, that's designed to then fit nicely into the 1500 series pelican hard case. Travel or transport with the hard case, pull out the soft case (already loaded and ready to go) and enjoy the shoot. I still prefer the PortaBrace bags, and when needed I just toss those into one of my bigger Pelican cases. The 1527 is convenient.
TNielson-18
