Best way to attach JB awning
jtakau
I recently purchased James Baroud Explorer Evolution RTT and awning.
What is the best way to fix the awning to the tent/roofbars/roofrack?
jtakau
I am using BMW X5 with Thule load bars, so I end up attaching the awning to the end of the load bars with bolts. A little bit of work, mostly because the space is a bit limited for tools, but I think that end result is quite nice.
I suspect that I will have to come up with some solution to cover the gap between the awning and tent/car so that it would be fully rainproof, but we will try this setup now and see what modifications will be needed later.
I have to say that I found it strange that the awning did not come with any bolts to attached the mounts to the awning.
jtakau
First test drive showed that something in the set-up starts to make whizzling noice at speed of 90 km per hour. I was hoping that my set-up would allow drive at motorway speed, so next step is to check that there is no unnecessary gaps anywhere and perhaps try plain nuts instead of butterfly nuts as well.
wellsasw
