StephBarnard
For those of you that have installed a Planar heater on your trailer, a few questions:
(1) In the settings menu do you control the heater by the "T panel"? If not, why?
(2) In the same settings menu have you "check-marked" the Ventilation mode?
We recently finished the permanent install of a Planar 2D heater and set the heater to be controlled by the "T Panel" and (per the advice of the Planar folks/distributors in Surrey, BC) we also check-marked the Ventilation setting. We understand that if the Ventilation setting is check-marked the fan will run continuously as long as the unit is turned on. We were hoping it would be like our home heating unit that blows warm air into the house when the indoor temp is below our desired temp and then, when the desired temp is reached, the fan turns off.
Our concern is that if the fan is running continuously it could drain the battery quicker than we'd like (we do have a LiFePO4 battery and 100 watt solar panel), especially since we have an on-board fridge.
In the controller's manual is says that if the Ventilation setting is not check-marked that the heater will run continuously but adjust the heating power as needed to maintain the set temperature. So, in this mode do we need to be concerned that the diesel supply will be depleted too quickly and/or worry that the constant use of the fuel pump will drain the battery?
Thanks in advance for any input.
