Best years
FSH00
G/Day All,
Just wondering what you guys here in oz would consider to be the best years to look for if chasing a single cab canter or Isuzu 4x4 light truck? something pre computer/electronic I can trouble shoot & fix myself, 2000 to 2005 maybe or just a particular engine model that was good ? Would you go the canter or Isuzu ? looking at buying one in the near future.
Appreciate any feed back.
Thanks,
Pete.
Aussie Iron
Precomputer/electronic is around 1998 -2002 ( FG637 ) with a non turbo 4.2 litre engine. Fg649 still has a computer in the injection pump which does give some trouble at times, yes some are precommon rail.
The 4.2 litre engine does need a turbo fitting to it to make it a lot better to drive, that is not a problem. Usually cheaper to buy as they often come up at auction as Rural Fire Service Vehicles.
My thoughts,
Dan.
gait
I think the FG649 (with 4D34 motor) has an engine ECU (computer) which does throttle, measures temperatures and pressure, exhaust retarder, and talks to the computer in the fuel pump (long story somewhere in this forum was an unidentifiable error code from engine ECU which turned out to be the fuel pump computer telling it there was an error in the pump - a trip to Bosch solved it. The engine ecu is accessible through the OBDII port but its proprietary - I rely on blink codes to interpret errors.
FSH00
Thanks for the info guys much appreciated, I tried looking on line for historical spec sheets (canter) with no luck, any one have a link or info to where I can find any ?
PKDreamers
Overview
Price$66,438*Price Guide (EGC)
Number of Gears5
BadgeFG649
Drive4X4
BodyCab Chassis
FuelTypeDiesel
No. Doors2
Release Year2006
Seat Capacity3
Country of OriginJAPAN
TransmissionManual Overdrive
Colour 1
Full Specifications
Engine
Engine TypePiston
Power103kW @ 2900rpm
Engine Code4D34-3AT3B
Torque365Nm @ 1600rpm
Number of Cylinders4
InductionTurbo Intercooled
Engine ConfigurationIn-line
Fuel DeliveryDirect Injection
Engine Size (cc) (cc)3907
Fuel TypeDiesel
Engine LocationMid-Front
Fuel Capacity (L)125
Engine Description3.9
Method DeliveryElectronic
Engine Full Description3.9DT
Manufacturer Fuel DeliveryDirect Injection
CamPushrod
Emission StandardEuro 3
Number of Valves per Cylinder4
Engine Cycle4 Stroke
Compression ratio18
Dimensions
Wheelbase (mm)2780
Front Overhang1055
Length (mm)5135
Bumper To Back Of Cab1595
Width (mm)2030
Gross Vehicle Mass (kg)6000
Height (mm)3460
Gross Combination Mass (kg)9200
Track Front (mm)1665
Kerb Weight (kg)2495
Track Rear (mm)1550
Wheels
Front Rim Description16x6.0
Front Tyre Description7.50 R16 LT
Rear Rim Description16x6.0
Rear Tyre Description7.50 R16 LT
Rim MaterialSteel
Standard Equipment
2 Speaker StereoPower Steering
Adjustable Steering Col. - Tilt onlyPower Windows - Front only
Air ConditioningRadio Cassette
Central LockingSuspension - Leaf
Exhaust - Vertical OutletTacho
Intermittent Wipers
Sophia Lopez
