I will need finances to cooperate but I'm contemplating a build for a versatile bike that would see some bikepacking use. I already have a Salsa Enabler fork (135mm) and I'm eyeing a 2013 Soma Juice frame running 29x2.4 wheels.
There seems to be a raging debate over the ideal drivetrain setup. Singlespeed is an option. Derailleur is what most people know. Then there is Internal Geared Hubs (IGH) like the Shimano Alfine 8, Alfine 11 and the Rohloff Speedhub. The Rohloff is not an option at $1600 (hub only). The Shimano offerings are possible but wanted to hear any experience from others with IGH hubs.
I plan to run a singlespeed hub for the front wheel then a geared solution for the rear. I'm just trying to decide which direction to go. If you were building up a new rig that would see a mixed amount of use including bikepacking, what would you go with?
Thanks!
Thanks!
