Bilstein 5160s
MOAK
in our travels we recently did our first long stretch of forest roads in our fully laden F-350. The truck has the 4FX package. With the stock shocks there is a bit of porpoising that goes on after almost any whoop de do transition. I’m considering the Bilstein 5160s to replace the rear shocks. Coming from the Landcruiser world it would be a no brainer to step up to OME components which I did, I’m still in the learning curve with Fords & Overlanding components- photo for show! Thanks ahead for all advice & conversation. IMG_0886.jpeg
PacificNorthWestJeeper
Blissfully Lost
Call the guys at Accutune.com. With your setup you would benefit from tuned shocks. They will tune your shocks for each corner of the truck. They can steer you into the right shocks and tune them for you...
It will make the world of difference versus your OEM or 'off the shelf' shock.... I went with fox shock, remote reservoirs on my build (F550)... Good luck on your adventures, rig looks great, cheers.....
Accutune:
flipstick
