BJ70 Diesel - packed with goodies
Somehow I missed this posting when I just went to make a thread about having seen this in today's Bring-A-Trailer e-mail ... what I had typed up follows. I'm copying it over here so the ad is preserved should the CL link come down (and so that I can go back and delete my duplicate thread).
skibum315 said:
From the Bring-a-Trailer mailer this morning ... I can't believe it hasn't been posted here yet, you guys usually beat me to all the re-posts. Not mine, no affiliation, no comment, etc, etc, yadda, yadda ...
http://bringatrailer.com/2014/01/14/capable-1987-toyota-land-cruiser-bj70-diesel/, ... and the link to the CL ad: http://sacramento.craigslist.org/cto/4283948618.html
CL Copy for Posterity said:
Vehicle Description
Absolutely rust free, orig paint, no body work ever done.
$2499.00 Maggiolina roof top tent included as well as a Yaesu ft 2800m ham radio.
Absolutely flawless running condition, start it up, do the Rubicon and then expedition it from Alaska to Argentina if you want.
1987 Toyota BJ70 LandCruiser
24v, Turbocharged 3B diesel, H55F 5-speed, 38mm Split Tcase, PS, PB, AC, Tilt
Only 662 BJ70's were imported to Canada from 1985 -- 1987.
AXT Turbocharger kit w/ oil cooler
Factory A/C kit
2 ½ " Exhaust
Dual Optima Yellow-tops
4 core Rad, belts, hoses, T-stat etc
Marks 2.8 Tcase gears (62:1 crawl ratio w/ 2,400 RPM hiway range @ 70 mph)
35" Goodyear MTRs
Full Float JDM rear axle
ARB lockers F & R w/ 24v compressor
4.56 gears
Butch-Lewis Front Diff cover
1-ton Tie rods w/ 4x4 Labs custom Tie rod & Drag link
OME Heavy Suspension SUA
1" body lift
MAF U-Bolt Flip kit
ARB Bullbar w/ custom 4x4 labs oil cooler skid plate
Warn M8000 24v Winch
4x4 Labs Sliders, Side Rails & Tcase skid & rear bumper
Safari Snorkle w/ Pre-cleaner
20 AMP 24v to 12v Battery equalizer w/ 12v 6gang fuse block
Boost & EGT & Water Temp Gauges
Rear Storage Cabinet w. Fridge slide
Fj89
