Hello:
Mark asked about the roof rack on our '87 4runner after I posted some shots of the truck on the "random rig shots" thread. Here's some more information & photos:
Early 4runners have a fiberglass top aft of the "normal" pickup cab. The fiberglass top seems really strong, but might not be up to supporting much weight on rough roads. When we started looking for options for carrying more gear in our truck in the late 1990's we were lucky to encounter the guys at Stout off road fabrications in Albuquerque (no longer there, but Steve Hinken keeps up the good work at Hinken Specialty Fabrications, http://www.hsf4x4.com/index.htm, in Los Lunas).
They designed the base rack with 6 attachment points on the body and worked the legs to follow the window lines of the top. The also built a full length (47 x 84") tray supported by the base and extending over the 4runner's cab. We used to sleep up there without a tent when camping in the desert.
Currently we don't have the full length tray mounted. We're using a Yakima Load Warrior mounted sideways at the back with shovel and Hi-Lift mounts on it. One spare tire is carried forward of the Load Warrior and a gutter mount Yakima crossbar sits at the front of the cab. We can carry two single bikes plus a road or mountain bike tandem, the spare tire, shovel, jack, the mystery white tube (more later) and some light gear in the load warrior with this configuration. The truck has 3" lift & 800 lb capacity rear springs so all that rides well.
We vacillate a lot between using a trailer or a roof rack or keeping everything inside. The loaded rack does put weight up high, so we avoid extremely tippy spots with it. Gear in the roof rack stays much cleaner (especially bikes) than stuff in a trailer on dusty roads. On really long trips we'll carry the bikes on the top with the jack, one spare, shovel, and tube; then carry NATO cans with fuel, water, and other heavy stuff in the trailer (M416 w/ spring over axle & 6 lug Toyota hub conversion).
The 4 cylinder 22RE wasn't pulling all that very well until we re geared to 4.88 running 31x10.5x15 BFG ATs. Perfect power off the pavement with the trailer and all, but highway cruising is limited between 65 and 70, although the 22RE honestly hums along at 3700 when we need to go faster with a tailwind.
What's in the mystery white tube? You'll have to ask Chuck Hatchcock. He's the only one I've seen post about what we carry in that tube!
Howard L. Snell
![120641559-L.jpg](http://visual-escapes.smugmug.com/photos/120641559-L.jpg)
![121084958-L.jpg](http://visual-escapes.smugmug.com/photos/121084958-L.jpg)
![121084881-L.jpg](http://visual-escapes.smugmug.com/photos/121084881-L.jpg)
![121084610-L.jpg](http://visual-escapes.smugmug.com/photos/121084610-L.jpg)
![121084919-L.jpg](http://visual-escapes.smugmug.com/photos/121084919-L.jpg)
![121084858-M.jpg](http://visual-escapes.smugmug.com/photos/121084858-M.jpg)
Howard L. Snell
