Brand New Off-road Teardrop $15,000 1300 lbs! solar, propane, mattress and cooler included! located in SoCal
Rad Coast
Trailer features
-5x9 foot trailer 13x7 feet overall 72 inches tall from ground
-1300 lbs dry weight
-2x2 NATM certified welded steel frame
-3500 lb Dexter axel with 10 inch electric brakes and break away switch
-31x10.5 R 15 Federal Couragia M/T All- Season Radial Tires and aluminum rims
-2 inch removable coupler
-2 inch rear receiver
-Led tail, marker and license plate lights on 7 blade plug
-3 HD 5000 lb levelling jacks
-Solid once piece floor with fully polyvinyl underneath
-Painted aluminum .040 skin over a full birch construction
-Fully insulated 1.5 inch R-Tech foam board walls, roof and rear galley hatch
-2 30x36 inch doors with 16x26 inch half sliding screen windows
-2 led porch lights with switches inside
-2 Night vision under cabin red LED night lights
-Deep cycle 100 ah AMG battery one of the best on the market
-Progressive Dynamics 4045 power converter 3 stage battery charging wizard that will also charge lithium batteries (new style)
-30 amp shore power inlet
-100 watt solar panel mounted on rear hatch
-11 pound propane tank, bracket and braided stainless steel converter hose
Cabin features
-56x78x43 3/4 inside
-Everything is built from Baltic birch finished in low voc water based polycrylic
-5 inch full size memory foam mattress with removable cover
-10 speed Maxxair fan that pushes or pulls air in or out with built in thermostat
-Large cabinets with sliding doors 17 inches deep
-Electronics cubby with 2 fast charge USBs battery voltage monitor, 12 volt plug and 120 GFI protected outlet
-LED dome light with dimmer
-2 LED dimmable reading lights
-1.5 inch R-Tech insulation in walls roof and hatch! Keeps cool in the morning when the sun hits it and warm at night.
Galley features
-45 quart Roto moulded cooler
-All built from Baltic birch finished in low voc water based polycrylic
-58x19 main galley counter covered with vintage pattern Formica
-Upper galley storage
-Large under galley storage
-Large 22x26 inch cooler slide with 12 volt power
-1 GFI 120 outlet
-2 USB chargers and a 12 volt plug
-2 dimmable LED dome lights with touch controls
-Hatch is on two gas shocks, two locking Jeep hood latches, fully insulated and waterproof
rad.trailer@gmail.com
D883664F-66C0-46D4-B4B6-EFC7F9D06A1B.jpegBC09DFC8-4660-48D8-A356-FAB427A3751E.jpeg44DAEB4E-B506-46C0-AD3B-18E1BEDBC457.jpeg03712FB6-04AA-46AB-9AE6-DF5964089DD9.jpeg987018B9-D3D0-4E87-AF05-8B40BE0CE917.jpegF1BEBB64-0971-43B5-8C95-8E4005FA1F49.jpegD649B6B6-9747-4B1E-98F8-33EBB0B75703.jpeg3442EBB7-08BC-4D21-BA2A-3B6339CB9417.jpeg4CF5F7A5-1A58-4C72-861F-3725EB288A32.jpeg
Rad Coast
What material is the frame? Looks like it's welded to the front trim. Aluminum?
Steel frame, that’s black silicone around the cutout of the trim. Built by NATM certified trailer manufacturer 2 year warranty on welds
gates_kr
Great looking trailer! ? Would there be any way of adding a roof rack? I need to carry a roof top tent for the kiddos.
Smithmds77
