http://gizmodo.com/breitling-emergency-ii-a-satellite-distress-signal-on-487271786
Breitling's original Emergency watch first launched back in 1995 and was able to broadcast a distress signal on the 121.5 MHz analog band allowing ships, planes, and other vehicles to track it. But if your approximate location wasn't already known, it made locating the signal a bit tricky. So Breitling is introducing an upgraded version of the watch—the Emergency II—that adds the ability to send a distress signal to satellites circling overhead, so no matter where on Earth you're lost, you can be found.
The Emergency II still broadcasts a 121.5 MHz analog signal, but that alternates with the new 406 MHz digital signal which can be tracked by the five COSPAS-SARSAT search and rescue satellites. To ensure the signal isn't accidentally triggered, the user has to pull out a set of long antennas on either side of the watch, and the emergency signals will alternately broadcast for up to 24 hours with the Emergency II's built-in rechargeable battery.
Made from titanium so that it's all but guaranteed to survive whatever emergency situation you find yourself in, the Emergency II will cost you just under $19,000. An expensive investment, for sure, but one you'll be glad you made if and when it saves your life one day.
