Alright guys and gals, here it goes. Trying my hand at a foam/fiberglass truck camper build. The truck camper will be for a 2010 F150 4 door 6.5' bed. I did have a real nice truck camper last year that I ended up selling. It was a 94 SunLite Hideaway, dry weight of 1400lbs. I added 300 watts of solar with 240aH battery setup and also a Wave 8 heater I got for a steal and it really was a pretty sweet setup. It was just so cumbersome and with panels and gear I had to be close or over my 1950lb payload rating. Nonetheless I did a ski trip cross country to Jackson WY and Big Sky MT and it all worked good. Things I didnt like about the camper was first off the weight. You definitely knew that you were hauling a lot of weight, the truck drove fine just had to take it easy. I was not willing to pay up for the fancy frame mounted tie downs so I used bed rail clamp on's that were a pain in the ass. They were a pain to fit on my bed as this year of f150 barely has a gap under the rail. I also didn't come close to using all of the space and storage that camper had. Here some pics of the old setup sorry they are so small.
Instead of going on further about my old camper here is a list of things that I want this new one to improve on or have equipped.
- Weight! (shooting for the shell to be 500lbs or less)
- simpler tie downs that go to existing mounts on my truck bed
- waterproof (had to fix cabover damage and roof seam on my old one)
- better insulation (i did survive a -23 degree night in my old one, but there was lots of drafts and could really feel the cold comming off those plywood walls)
- ski/fishing rod storage
- solar (eventually)
Dimensions: From all of the different camper builds it seems like a foam composite camper is the route to go, especially for a 4 season one. The camper outside dimensions will be 8' long x 7'8" wide x 6'x6" high. It will not be a cabover and the back of it will rest on my tailgate. My old camper was so heavy I would take the tailgate off before loading worrying about all the weight on it.
I started last weekend and made good progress for just working on it Friday night and Saturday. The camper shell will just be foam and fiberglass. Inspired by this build (https://expeditionportal.com/forum/threads/build-fiberglass-foam-truck-camper.205977/) where they used just 1/2" foam and fiberglass my shell will just be foam and fiberglass too. No wood or metal framing. Im thinking about having cedar strips for the door/window frames but we will see. That build did use denser foam than I have but I am going with Foamular 250 which is 2" foam board insulation so I think it will be plenty strong. A little late but anyone have concerns with this?
So I started cutting and gluing the foam on Friday. Here I am gluing the sides to the base/floor piece of foam. I got 2 1/4" sheets of plywood so I would have nice working surface the garage floor at my rental is greasy and nasty. I also used saran wrap below the foam base piece and on my "clamps" so I wouldnt glue this thing to the floor or the clamps. I sanded all surfaces I glued to as it looks like there is some glossy coating on the tops and bottoms of the foam. I wanted to ensure I had a good surface to bond and to prevent any potential delamination. I plan on roughing up the foam before I fiberglass as well. I used gorilla glue, wayy to much...
Here it is all clamped up. For cheap clamps i used 2x4s with screw in hooks and ratchet straps. I really did not need a ton of pressure so this worked good. I figure the glue is basically to just hold things in place before I get fiber glassing. That is where I am bank all the strength comming from. Dont get me wrong I still want things squared and tight when I glue. I used boards on the inside as there was a slight bow in my foam and this kept the sidewalls straight and flush along the edge of the base foam.
Here is how it turned out, looks like I have some glue sanding to do. Oh well at least it all turned out square and solid. I was satisfied with the first glue up and continued on. The glue takes 24 hours to cure so I had to work around that.
Saturday I took the clamps off the base (pictured above). I then got to gluing and cutting the main front and back walls. When I say front and back I mean the wall that will go up against the front of the truck bed and the wall that you will walk into out the back of the pickup.
I had to then wait until Sunday for the glue to cure on these two walls. I decided not to cut the door out yet as I was worried that I would decrease the strength too much and things would start to potentially buckle during the next glue up. Before the next glue up I made sure to get the excess glue off of the base so I would have square corners to glue these wall too.
Here it is clamped up. It was nice to have a second set of hands for this. As you can see the camper is starting to take shape and is upside down with the base piece at the top. I clamped the sides with the 2x4 clamps and used my 8' long plywood to ensure the walls were a square 8' apart. We also used barbecue skewers to keep things flush. A lot more glue sanding to do...
From this point I am going to clean up the glue and start fiber glassing the base. I plan on glassing from the base just down to the ratchet strap or so to make the whole bottom more solid. I have resin and a roll of 1.5oz chopped strand mat on the way and plan on using 2-3 layers, maybe 4-5 on all joints. I am absolutely going to do some test pieces before glassing the camper to see how much strength I gain with each layer added. I will post the results. I have used 2 part epoxies in the past for potting electronics but have never worked with fiberglass or polyester resin.. I chose 1.5oz chopped strand after talking to someone who does custom fiber glassing for a living. Also just one of my observations, but from all the posts I have seen everyone always has issues/bubbles with corners and woven cloth when making these. Please chime in if you have any advice for me on that or any thoughts on the camper design and build in general! Thanks everyone, really excited about this build
