Bush Co. DX27 RTT & 270XT Awning
ThunderUT
After much thought and waffling I have come to the conclusion that I need to sell my RTT with or without the awning. I have used this tent in many different conditions, snow, rain, wind and the heat of summer. I can honestly say it has been the easiest, most reliable and convenient home away from home I have every had and I have had a few. Below are the specs on the tent. The awning is a 270-degree, LH (drivers' side) awning with sides. The sides are not Bush Co. sides rather they are Oztent that I had from a previous awning which I adapted but they work as well as any would.
Price for the tent only - $2500 (retails $4k plus tax and shipping) (includes 2-100w solar panels)
Price for the tent w/awning & sides - $3500 (retails $1,500 Awning, $250 Oztent straight walls plus tax & shipping)
Awning not for sale by itself as I would keep it for future use.
Bush Co. awning wall kit - $1,150 plus tax & shipping (information only as they are not part of the sale)
Total new would be close to $6k with the Oztent sides or close to $7K with the Bush Co. sides.
In my opinion quality of build is as good as they get. Alucab and Bush Co. build some of the best RTT's available on the market. Bush Co. quality rivals what I have seen from Alucab.
Located in St. George, UT
Bush Company DX27 Clamshell Rooftop Tent
Designed and manufactured in South Africa. Features include an extruded and welded aluminum alloy frame, a large rainfly at sides and rear, full length roof mounting rails, plus the convenience of setting up/packing down in under 90 seconds
DX27 Clamshell Rooftop Tent - The Bush Company
  • Aluminum extruded frame.
    • Fully seam welded lightweight alloy powder coated frame
    • Stainless steel fittings
    • Welded cargo rails for attaching accessories or the optional roof load bars.
    • Internally reinforced roof, load rated to 440 lbs. closed, or 110 lbs. open.
    • ‘Ezi-Slots’ on the sides of base and top frame for easy attachment of accessories
    • Two HD aluminum extruded rails under tent w/T-slots for easy mounting
    • External 50-amp Anderson plug mounted to underside of tent at hinged end
  • Exterior Dimensions (closed):
    • Length: 88 ½” (including hinges & handles)
    • Width: 57″ (including gas struts)
    • Height:10.94″ (including roof rails and base extrusions)
  • Max Height (exterior, open):57”
  • Max Height (interior, headroom open): 55”
  • Weight: 207 lbs. excluding telescopic ladder
  • Tent:
    • Material: 420 gsm waterproof polygram ripstop canvas
    • Air vent above rear entrance with midge mesh and zipped canvas flap on inside.
    • Three entry point to tent, rear, left and right side.
    • YKK zippers at all entrances
    • Internal hard wired LED light.
    • Electrical power w/twin USB & CIG Socket plug, mounted to internal roof
    • Sirocco fan roof mount w/fan, wonderful for those warm nights
    • 4.7″ above mattress (tent closed), room for bedding, pillow, fishing rods, etc. This is an awesome feature as there is room for a duffle bag and other reasonably sized personal items as well.
    • 3 storage pouches on inside of roof, & 1 large pouch on each side at hinged end.
    • Thermal marine carpet underneath mattress and carpeted internal roof liner.
  • Mattress: super high-density foam with removable zipped canvas cover.
    • Thickness: 2 ¾”
    • Length: 84”,
    • Width: 55″
  • Rainfly:
    • Large removable one-piece, 420 gsm waterproof polygram ripstop canvas
    • Heavy duty 8mm spring steel poles
    • Adjustable storm straps windy conditions.
  • Ladder: Telescopic (100.3″L), attachment points rear and sides, canvas storage bag.
Bush Co. 270 XT MK2 Awning
  • LH Drivers Side
  • 86 sq. ft. of shade/protection
  • Length: 90.5"
  • Weight: 61.3 lbs.
  • 315gsm/11.3oz poly-cotton rip-stop canvas
  • Awning bag is 460gsm/16.2oz poly-cotton rip-stop canvas with YKK Zippers
  • Self-supporting, no legs w/awning but sides do have legs that can be used when using sides
Bart605
