Dangriga
Finally getting around to installing an alarm system in my 2006 E350 SMB. I have researched the installation process Best I can, but still have a few questions. I don’t think these questions are specific to this alarm, as any DIY installation will need to identify these wires.
1. Not sure if the E350 is a positive or negative switching parking lights and how do I test.
2. Do I need to connect both the + and - door trigger input wires?
3. There is a wire that is labeled as “ground when armed I put (-)”. Do I just ground this wire? What is it’s polarity when the alarm is not grounded?
4. Apparently each door has it’s own lock/unlock wire. It says to join them all together when connecting to the relays for a 5wire setup. Is there a location in the van where these wires all pass together? They also mention diodes are needed but the alarm did not come with diodes. Why are they needed?
I know this sounds specific, but hoping some one here has already gone through this and can shed some light and advice. Thanks!
